Hypertherm 30 vs Hobart 40i for first plasma cutter.
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #11
Thought Hobart was made here.
That is becoming questionable.... The new Hobart 200i (or i200) inverter combo welder (Stick/TIG/MIG) is reported made in China.... Information came up on Hobarts Weld Talk and it was not denied by local Hobart Expert...
Dale
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #12
Hobart - ITW product origin was established in 2004 when management screwed up and ran out of wire drive assemblys made by another ITW company in the Far East. Dey tried blowin smoke including givin false info to ROCK who ran de show. Dey got BUSTED by fellow who did his homework.
Dat led to evacuation of Weld Talk and WeldingWeb lighting up.
Hobart ain't been American made since dey started paintin de machines white.
ITW is BS & Empty Promises.
Ended up with the hyprtherm 45xp. What痴 a good air dryer/filter for this thing.
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #14
Motor Guard filter. Easily replaceable, large filter medium. Can be dried out and reused, takes a long time. Keep spares on hand.
So I messed around just a little with it. Here’s a 1/2” ar500 bar I cut through. I am going to have to practice cause this thing just burns right through stuff. I find myself pausing to try to see the plasma tail. 9601C8D6-5990-4923-8DEE-4431EE42B0C5.jpeg
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #16
So I messed around just a little with it. Here’s a 1/2” ar500 bar I cut through. I am going to have to practice cause this thing just burns right through stuff. I find myself pausing to try to see the plasma tail.View attachment 679377
Dang fun... isn't it? I do the same trying to gauge my speed by looking at the tail and not focusing on a constant speed drag. I might look into investing in a tool to better roll along with so the tip doesn't get hung up and jerky. It has be a dream cutting with my 45xp.
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #17
You think arguments about welding get rough, compressed air drying makes rod fight look like a happy day at daycare.
Just 1 filter just ahead plasma not going to cut it. Compressed air roaring toward nozzle at warp speed no single device got enough time to pull water out. Not even refrigerated dryer unless it discharging into tank before machine.
15+ years back Franzinator popped up on Hobart, sits between compressor and tank and knocks water out of air by rapid cooling. Biggest temp change available der. Naturally 1000 fools post how can't, won't engineering school all over place. Men who built Franzinator say it works. 15 years down road pretty much every post on www says it works.
Water leaving compressor in either vapor or micro drop, gets slammed into cold surface condense, water don't hit wall has to make 180 turn and more falls out, what stays hits second cold wall above inlet and more condenses all in less den 10th of second.
OK, so now air in tank at colder and drier condition, but tank so big most air don't encounter room temp cold wall and water rides along. Airstream goes into pipe to machine. Pipe usually up on wall so most genius run T down from pipe to air connector. WRONG, Lot of water sitting in pipe relaxing and waiting. Air line generally not flowing so water has time to grab recliner on bottom of pipe. Air starts to flow, water rides along. Air pipe needs to be tapped going UP and stream needs to make 2 turns to go down to outlet. Dat leves water in recliners in horizontal. Best if water has drip leg to hang out in, but dat too much trouble for most 'system designers'.
Now comes war between what best next. DOH, where you live makes big difference.. You on Louisiana coast you got 10 times water of guy in Arizona. Nice thing, plenty salesmen waiting to sell you der crap er I mean fine product. Hustler A got fine Chink plastic spinner, Hustler B got plastic housing holds special toilet paper, and Hustler C got hunk of pipe full of special beads.
Guess what? You can make your own way better and way cheaper. Situation got so bad Hypertherm included detector in machines to display "Insufficient air". Biggest problem, machine innards get plugged up wid toilet paper fibers dat get like concrete.
How you solve dat? You find small scintered metal filter dat plugs up before machine plugs and install at machine air inlet.
Want to make your own absorbant silica gel dryer, you can. Hunk of pipe, handful of fittings and bag of silica gel kitty litter. You get actual real bragging rights instead of just being another guy who Master Carded cause he can't build squat.
Want to know easy way to minimize water coming into compressed air system? Put air intake more den 13 feet above ground, higher if you in valley wid lot of fog. Remember tho, intake line gotta be bigger den inlet of compressor. At least twice diameter of compressor inlet.. 2" PVC good starting point and minimize number of elbows.
Whole bunch of tricks to compressed air.
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #18
I love my plasma cutter, even if it's the Harbor Freight version... I cut through some random scrap yard steel making a bracket like butter then tried drilling a couple holes through it and realized it was something hard after I burned up the first bit then tried another with similar success... :)
If possible I use a guide and just watch the back side to see if it is going out at just a slight angle. For a guide I have been using the Harbor Freight magnet bars spaced away appropriately (10mm in my case) for straight cuts, it makes things look very nice...
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #19
gotta love plasma!
   / Hypertherm 30 vs Hobart 40i for first plasma cutter. #20
gotta love plasma!
Till you run it at Carbide or other ceramic manufactured metal. Give it try, you ain't gonna hurt de machine or de carbide.
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2025 IRTPL 10,000lbs Two Post Automotive Lift (A55974)
2025 IRTPL...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Super Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
PALLET OF HOLE SAWS AND MISC. (A58374)
PALLET OF HOLE...
