hydrulic oil
/ hydrulic oil #1
ditt
does anyone out there know what the difference is between for instance New Holland hyd oil and a brand like Farm King or TSC ?
wondering about with a new tractor (TC30) and old cylinders that have other brands of oil in them when we hook them up looks to me like this oil would be mixed in with the new oil when the attachment is used ?
/ hydrulic oil #2
The first time I purchased oil, I went to the NH dealer and asked for the specific type mentioned in the manual and all I received for the trouble was a blank look.
They sold the same basic oil as TSC.
/ hydrulic oil #3
I use engine oil in the JCB. I guess them being British they like the stiff upper lift.
/ hydrulic oil
dumbdog, "THAT"S" exactally what I thought the main difference is the price $16.50 versus $9.25 per 2-1/2 gallon size.....
Thanks for your input, appreciate it !
ditt
/ hydrulic oil #5
<font color=red>I guess them being British they like the stiff upper lift. </font color=red>
OHHHH!! Thats BAD. /w3tcompact/icons/smile.gif
/ hydrulic oil
wroughtn harv, Well if it works that is the way to go. I have heard that engine oil in the hydrulic system would foam real bad and cause air pockets and rough unstable attachment use ?
ditt
/ hydrulic oil #7
<font color=red>and old cylinders that have other brands of oil in them when we hook them up looks to me like this oil would be mixed in with the new oil when the attachment is used </font color=red>
Yes the old stuff will be mixed in. When ever I use an old hydro powerd attachment on my Ingersoll, I wait till its almost time to change the fluid.[The old Case's, and Ingersolls do not have a hydro filter/w3tcompact/icons/frown.gif] That way any old stuff gets flushed out. [God knows what the PO used in there hydro system]
/ hydrulic oil #8
Just depends on the design. For instance, our cat front end loaders use 30w oil in the engine, and in the common hydraulic/tranny system... and that is manafacturer spec.
I still buy the expensive 134 oil for my new holland 1920, but do buy some cheaper oil that TSC sells labeled as for 1939-1952 ford tractors, for my old ford 8N.
Soundguy
<font color=blue>wroughtn harv, Well if it works that is the way to go. I have heard that engine oil in the hydrulic system would foam real bad and cause air pockets and rough unstable attachment use ?
/ hydrulic oil #9
<font color=red>have heard that engine oil in the hydrulic system would foam real bad and cause air pockets and rough unstable attachment use ?</font color=red>
The Case/Ingersoll tractors also use motor oil in the system. Eather 20w40[what you can only get from Ingersoll] or 15w40[Rotella is the best] The only time I have had a problem is when I had a suction line go bad, and was sucking air. BTW, If you don't know about the Case/ Ingersoll tractors, the hydro system puts out between 8-10gpm. I don't rember the psi, but I think 2000, to 2500.
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2011 Porsche Panamera Sedan (A61574)
2011 Porsche...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
