Hydrualic winch
/ Hydrualic winch #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
Has anyone used rear aux hydrualics to power a winch?
I'd like to make one I can use in the rear with backhoe (unsure how I can make that work lol) and also the front, I get in some sticky situations but mainly so I can rescue cars in the snow in winter... not as a job, more of a helping neighbors out when the big storms blow in.
Which winch can I find used for reasonable? I'm thinking 10-15k rating is all I'd need.
/ Hydrualic winch #2
I built one for my tractor. Uses the third spool from the loader valve. It's come in handy several times.
  • Good Post
Reactions: TWD
/ Hydrualic winch #3
Had a log grapple with 10,000# warn hydraulic winch ssqa mount. Added cat1-2 3pt mount. Needed bucket, grapple or blade to anchor to pull anything. Scary strong, could easily bend or hurt tractor.
Have milemarker 10,500# hydraulic winch on front of truck. Two speed diffidently helps playing cable in and out.
  • Good Post
Reactions: TWD
/ Hydrualic winch #4
On right of way (ROW) clearing tractors hydraulic winches are common. They are often 20k winches and are run off of the rear remotes on 100 hp tractors.
I cannot suggest what you need. If your pulling cars up cliffs 10k might not be enough. However for a lightly stuck car 10K is plenty.
/ Hydrualic winch #5
I have a 10k winch on my JEEP and any load I am trying to pull that is to heavy it just slides my 4.5k JEEP....What you are trying to pull is relative to weight of puller...
2022 EZ-GO ELITE...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Year: 2013 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 201,750 (A64557)
Year: 2013 Make...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
1975 HOMEBUILT TR-AXLE LOWBOY TRAILER (A64278)
1975 HOMEBUILT...
