Hydrostatic Transmissions explained
   / Hydrostatic Transmissions explained #2
For the visual learners out there:
Keep in mind a conventional tractor does not have two hydraulic motors like this fork truck.
It only has one hydraulic motor that drives a conventional 2 or 3 speed gear box (range selector) and the usual differential components. However for you power trac guys, I believe there is a hydraulic motor on each wheel.
So from the hydraulic motor on backward to the final drives, the hydrostatic equipped tractor is pretty much the same as a conventional gear tractor.
   / Hydrostatic Transmissions explained #3
Thanks. Good reading.
I started operating hydrostatic machines when I was 18. Don't laugh, it was a Wheel Horse tractor converted into a hydraulically articulated airplane mover with an oversized sun strand pump and no front axle. It was cantilevered with a rear steel fork for picking up nose wheels with a hydraulic cylinder operated lift. You sat backwards on the hood with the steering wheel between your knees. Anywho, I had to work on it once in a while.
Then around 1989 we bought that late 70's IH2500b tractor loader. It was HST. So I purchased all the manuals for that and got a pretty good understanding of how it worked.
Now we have the PT425. It's a beautifully simple machine. Just beautifully simple. And that's what I like about it. Almost as simple as my '70 Nova with the 230 L6 and three on the tree! :thumbsup:
   / Hydrostatic Transmissions explained #4
Nice , Makes sense that my owner manual says change the HST filter every 200 hours If the HYD oil stays in the loop:)
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
