Hydrostatic trans. question for 2305
   / Hydrostatic trans. question for 2305 #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
I just got an LX-4 cutter for my 2305 and used it the first time. It works great for cutting the pastures, but the ride was very rough. I ended up with 10 psi in the tires and a piece of plywood with some foam on it between the seat and the rubber cushions. That helped quite a bit.
I could mow using nearly the highest speed in the low range or at a low speed in the high range.
Which is easier on the trans? It seemed to put out a little more heat in low range, but that's just am impression.
Thanks in advance!
Thanks in advance!
   / Hydrostatic trans. question for 2305 #3
I hope that's 10 psi in the rear tires. You can easily push the front tires right off the rims at lower than about 20-22 psi in them.
Sounds like you're putting in a plug for the newer seat on the 2520 and probably the 2320.
Ralph
   / Hydrostatic trans. question for 2305 #4
Ralph
   / Hydrostatic trans. question for 2305 #5
Careful with that poor radiator mount. You can damage the radiator on rough ground.
   / Hydrostatic trans. question for 2305 #6
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
71066 (A49346)
71066 (A49346)
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
