hydrostate pully
/ hydrostate pully #1
jerboy
john deere x304
what would be the effict of puting a smaller size pully on the trans?
/ hydrostate pully #2
More gear reduction. Or the belt slipping. A smaller pulley is less surface for the belt to grip.
/ hydrostate pully #3
Wouldn't it be the other way.....less gear reduction if the rear pulley is smaller?
/ hydrostate pully #4
Yeah, now that I think about it I think you’re right.
/ hydrostate pully #5
X3 series did have 2 different sized input pulleys. Will you notice a speed difference? Not unless you're doing a science experiment along side another. In theory the smaller pulley would increase the speed slightly. It may increase the likely hood of the dreaded traction belt dropping down off the drive pulley onto the clutch, but there is a belt change for that. No guide of course...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2022 EZ-GO ELITE...
Steiner 450 (A64126)
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
