Backhoe hydrolic oil
/ hydrolic oil #1
paulie
morristown
kubota b21
Need to change hydrolic oil. See my b21 has a hydrolic filter and the hst transmission filter. Is there just one drain plug for the common tank? Also is there a specific position the loader and the bachoe should be in to check the level of the fluid? Thanks in advance.
/ hydrolic oil #2
On my b7510 it is one resevoir with two filters and you are supposed to pull out the bango bolt on the suction line for the hydraulics and clean the screen on it. You should try to find an owners manual it's hard to figure out some of this kind of stuff and the adjustments without one.
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
2014 Nissan Sentra Sedan (A61574)
2014 Nissan Sentra...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
