hydrolic noise
   / hydrolic noise #1
brother Dave
Gray Court, S.C.
Farmtrac 535
I have a 2009 Farmtrac 535; changed the hydroic filter, now have noise like air being pumped through system, almost like a loud rattle. Turned steering point to point, lifted 3ph point to point, still makes noise. Any ideas?
   / hydrolic noise #3
A loud rattle in hydraulics is sometimes related to pump cavitation.
   / hydrolic noise
I checked the filter and found nothing out of order; and I tightened the hose connection (didn't need it), have plenty of fluid for the 3ph. Any other suggestions?
   / hydrolic noise #6
Did you remove a pressure hose and place in a bucket to see if the pump was pumping at the pump specified volume as in GPM?
Look for air bubbles in the hyd fluid stream.
If you have a hyd gage, what is the pressure reading?
   / hydrolic noise #7
Where is the filter you changed located?
Pump inlet or suction line
If pump inlet where you able to pre-fill the element before installing or is it horizontal?
If pump inlet, Are you 110% the seal or gasket was not damaged or compromised in any way?
Return line: This should not cause cavitation unless the seal is allowing air to be sucked in from fluid flow and aerating the reservoir.
   / hydrolic noise
I don't have a hydraulic gage, but I have one for water pressure on my pressure washer. Will that work?
   / hydrolic noise
I am going to try another new filter, then another site. You assumed too much with your spelling test! I know how to spell, I do have a college degree and I'll bet you understood what I was trying to convey to you, regardless of how the word (gauge) was spelled. I have been down many roads in my long life and continually run into people who are overly impressed with themselves. Which is more correct? Insullting or insulting?
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
