hydrolic filter
/ hydrolic filter #1
cjd
dryden va
ford335
where do you find hydrolic filter on a ford335?
/ hydrolic filter #2
best I remember, it's under the right hand step
/ hydrolic filter #3
Which hydraulic filter are you referring to, the one for the 3 point hitch or the one for the loader if it has one.
/ hydrolic filter
both do they have two?
/ hydrolic filter #5
The 3 point/rear axle hydraulic filter is a spin-on type under the LH step. The loader filter is located in the hydraulic tank on the nose. It is a cartridge type under a 5" round cover on the top of the tank with a single bolt.
/ hydrolic filter
thank you
/ hydrolic filter #7
IIRC the 335 doesn't have the hard nose with the hyd tank. Hence, I say the loader filter is inside the bottom of the loader frame LH side, just outboard of the clutch pedal where the suction tube connects.
/ hydrolic filter #8
RickB,
I agree. Thinking hard nose industrial type.
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
2025 KENWORTH T880S DUMP TRUCK (A63276)
2025 KENWORTH...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
