hydrolic filter
/ hydrolic filter #1
cjd
dryden va
ford335
where do you find hydrolic filter on a ford335?
/ hydrolic filter #2
best I remember, it's under the right hand step
/ hydrolic filter #3
Which hydraulic filter are you referring to, the one for the 3 point hitch or the one for the loader if it has one.
/ hydrolic filter
both do they have two?
/ hydrolic filter #5
The 3 point/rear axle hydraulic filter is a spin-on type under the LH step. The loader filter is located in the hydraulic tank on the nose. It is a cartridge type under a 5" round cover on the top of the tank with a single bolt.
/ hydrolic filter
thank you
/ hydrolic filter #7
IIRC the 335 doesn't have the hard nose with the hyd tank. Hence, I say the loader filter is inside the bottom of the loader frame LH side, just outboard of the clutch pedal where the suction tube connects.
/ hydrolic filter #8
RickB,
I agree. Thinking hard nose industrial type.
UNUSED FUTURE PSM49 TRUCK MOUNTED SNOW MELTER (A65055)
UNUSED FUTURE...
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
UNUSED JCT 96" PUSHER BOX (A65055)
UNUSED JCT 96"...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
20ft T/A Utility Trailer (A64557)
20ft T/A Utility...
UNUSED IRANCH IRTPL TWO-POST LIFT (A65055)
UNUSED IRANCH...
