hydrolic filter
/ hydrolic filter #1
cjd
dryden va
ford335
where do you find hydrolic filter on a ford335?
/ hydrolic filter #2
best I remember, it's under the right hand step
/ hydrolic filter #3
Which hydraulic filter are you referring to, the one for the 3 point hitch or the one for the loader if it has one.
/ hydrolic filter
both do they have two?
/ hydrolic filter #5
The 3 point/rear axle hydraulic filter is a spin-on type under the LH step. The loader filter is located in the hydraulic tank on the nose. It is a cartridge type under a 5" round cover on the top of the tank with a single bolt.
/ hydrolic filter
thank you
/ hydrolic filter #7
IIRC the 335 doesn't have the hard nose with the hyd tank. Hence, I say the loader filter is inside the bottom of the loader frame LH side, just outboard of the clutch pedal where the suction tube connects.
/ hydrolic filter #8
RickB,
I agree. Thinking hard nose industrial type.
