Hydro top link
/ Hydro top link #31
I was thinking more along the lines of these:
King Kutter 84" Dual Edge Land Grader
I think what you will find is that when you put the top link in float mode when using a box blade or a LPGS as in your link, the implement will roll forward completely collapsing the hydraulic top link and the implement will be riding on the very front edge only.
Try it yourself, but pretty sure that it will not work as you are thinking that it might. ;)
/ Hydro top link #32
I don't own either implements yet, and it might be a while before I can try it. :) It's possible I won't see my tractor at my property for another month.
For the geometry to work on the LPGS the bottom links need to be pretty close to grade or you'd be correct about it wanting to roll up.
/ Hydro top link #34
The stroke and cyl length will depend on your tractor mount pin to implement pin distance.
/ Hydro top link #35
With my box blade attached and in a level position, the length from pin to pin is 24".
/ Hydro top link #38
Thanks for that I was wondering how much drift to expect
Don't think there's a good way to answer that. It depends.
In my limited experience, two tractors with top and tilt, drift is most often the result of the spool valve, rather than the cylinder. My new (now one year old) B3350 tilt cylinder (welded ends and installed by myself) had something like 1/2 to 5/8" per hour with a heavy load - all in the spool valve as when the Quick Connects disconnected, no more drift down. In use, it drifted enough to be frustrating - set the bushhog level and then get to keep readjusting the &%^$ thing. Adding a pilot operated check valve solved the problem. Note that I did not order float function on the rear hydraulics so nothing lost and a lot gained. I was aware I could set tilt, then disconnect hydraulic hoses to lock it up, but that seemed a band aid fix.
The top cylinder I ordered from surplus sales came with DPOCV, so no drift there, locks solid. Since by bushhog has a chain lift to the rear, I've got all the float I need for rough terrain. 3-point float works for all else where float is needed.
/ Hydro top link #39
What bore size cylinder are you guys using? I'm trying to decide if I should get a 2-1/2" or just got with a 2"
my new kioti NX5510n has cat 1 on the tractor side and cat 2 on the link ends, but im using a cat 1 quick hitch.
/ Hydro top link #40
I typically recommend a 2 1/2" unit for your size tractor.
2014 Forest River Rockwood Premier 2317G S/A Pop Up Camper Trailer (A59231)
2014 Forest River...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
Unused 2025 CFG Industrial H12R Mini Excavator (A59228)
Unused 2025 CFG...
S/A Yard Dog Truck Tractor (A59230)
S/A Yard Dog Truck...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
