Hydro pump GPM?
/ Hydro pump GPM? #1
DetroitMike
Michigan
1500D
Does anyone know the output rating of the hydro pump on a 1500D in gallons per minute and psi? And, when installing a loader like a Koyker 110, will this pump do the job when plumbed correctly?
Thanks
/ Hydro pump GPM? #2
I don't know what the pump capacity is, but I can tell you that everyone uses the tractor hydraulics for loaders on the YM1500D. If you look at the pump, it should have a tag with the flow and pressure on it. The flow is normally specified in cc, and the the pressure in bar.
/ Hydro pump GPM? #3
My book shows @ 2400 rpm the flow rate should be about 5GPM @ 1500 psi. Pressure can go as high as 2200psi.
/ Hydro pump GPM? #4
I'm impressed.... Our old 8n's olny get 2.9 gpm, with the slightly newer ( and bigger NAA pumps getting 4.8 gpm...
Not bad at all..
Soundguy
/ Hydro pump GPM? #6
I have a 1500D with a Koyker 110 and it works great. It's amazes me what I can do with this little tractor and loader. Don't know how I ever got along without it!
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
2015 Kawasaki Mule 4x4 Utility Cart (A61572)
2015 Kawasaki Mule...
2022 EZ-GO ELITE...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
