Mechanos
Veteran Member
The battery is fine. One thing that I hadn't considered until now is that the starter may be getting weak. Those are a tad pricey.
What kind of oil are you using in the engine?
Synthetic oil will allow the engine to crank faster in cold weather, that might be the answer.
Since the engine has less than 100 hours on it, I am still using JD Break In Plus which is 10W-30.
Also, if you are using JD Lo-Vis Hy-Gard oil I would not use a oil heating element. Just my $0.02.
