Hydro oil heater
/ Hydro oil heater #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I'm considering adding a hydro oil heater to aid in very cold weather starting. Since my implement pump is direct coupled to the engine, the starter has to turn over the engine and the hydro pump on startup. Even with a block heater, the starter has trouble turning the engine over fast enough on very cold days. A couple of times I've had to warm the transaxle in order to get the tractor to start. I'm looking at a low wattage (150W) stainless steel heater rated for oil immersion.
Anyone here have one of these on their tractor? If so, how do you like it?
/ Hydro oil heater #2
Here's a hyd oil heater offered by JD for a 955
AM880977 Assembly Line Parts ADD 9.72 USD
AR94493 Heater View/Update 79.49 USD
AR95434 Wire View/Update 21.87 USD
R34557 Clamp View/Update 1.37 USD
R44302 Tie Band View/Update 0.09 USD
Parts that have an issue will display a flag. *Subtotal 122.35 USD
*Total 122.35 USD
/ Hydro oil heater #3
I'd think with the range selector in neutral that the hydro pump isn't engaged.
Hydro oil is pretty light weight, about 5 wt.
Ralph
/ Hydro oil heater #4
Perhaps you're using the wrong trans/hydraulic fluid. Most UTFs - including JD303 for example - are about a 30W equivalent. Pretty sure the 955 should be using Hy-Gard, which is more like a 20W equivalent. My newer 3720 uses Lo-Vis Hy-Gard, which is even thinner yet; about a 10W equivalent.
//greg//
/ Hydro oil heater #5
Ralph
The hydro pump spins whenever the engine spins. The range transmission is after the hydro pump/motor.
/ Hydro oil heater #6
A word of caution on using immersed type oil heaters, they attract moisture and can cause some acids to form if they get above a certain temperature.
I would check the condition of your battery and terminals to make sure you are getting full power to the starter. Temps in MO should not be a problem especially with a block heater that I presume is operating correctly and has been plugged in for sufficient time to warm the engine.
/ Hydro oil heater
*Total 122.35 USD
Thanks... I was aware of those parts JD offers, but there is no way I would pay an extra $60 to $70 for a cardboard box with "John Deere" printed on it when I can order the exact same heater elsewhere.
The battery is a brand new Interstate (MT-51, if I remember the number correctly) and is kept on a maintainer. The battery cable ends and connections are fine too... the engine was just rebuilt about 55 hours ago and all of that was addressed during the rebuild.
Temps in MO??? How about -10°F today with wind chill of -36°F. While it is not often that we get that cold, it does happen. It is not uncommon at all to see 0°F. A couple of years ago we had a three week stretch where the daily high never got above 0°F.
/ Hydro oil heater
//greg//
Recommended hydro oil for the 955 is Lo-Vis Hy-Gard which is what I'm using.
/ Hydro oil heater #9
Farmed in central MN for years and temps of -10 were considered normal. Started our Gehl 4500 skid loader with the Ford 4 cylinder gas every day with no block heater. Dual HST and gear pump for loader turned all the time. Coldest actual temp was -44 in winter of 85-86. two weeks warmest day was -22. I have to believe there are people that live in colder climates with a 955 or similar that use these for snow removal etc.
good luck
/ Hydro oil heater #10
Could still be the battery. I've seen more than one new battery that was not up to spec and had to be replaced. Check it with a load tester if you have one. If you don't have one, some auto parts stores like Advance Auto will test it.
/ Hydro oil heater
The battery is fine. One thing that I hadn't considered until now is that the starter may be getting weak. Those are a tad pricey.
/ Hydro oil heater #12
What kind of oil are you using in the engine?
Synthetic oil will allow the engine to crank faster in cold weather, that might be the answer.
/ Hydro oil heater
Since the engine has less than 100 hours on it, I am still using JD Break In Plus which is 10W-30.
/ Hydro oil heater #14
Engine with this few hours (55 hrs) will still be very tight which doesn't help in cold weather starting. In similar situations, I've used a battery jump pack to aid in starting just to get past the very cold weather. Next cold spell like this (possibly next winter?) the engine should be broken in and you just may not have any more problem with hard starting.
Also, if you are using JD Lo-Vis Hy-Gard oil I would not use a oil heating element. Just my $0.02.
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2022 EZ-GO ELITE...
2016 John Deere 6155R (A64119)
2016 John Deere...
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
