Hydro help
/ Hydro help
/ Hydro help
I can see the impellers spinning. That pump should be good right?
/ Hydro help #64
Shaft Key ? Is it on the pump shaft and all intact? If it's not the motor won't turn it. I'm guessing no it's not. But the good thing is turning it by hand a Fluid is moving. That's a good indication the pumps good.
/ Hydro help #66
??? Does the Hex Head go into a Female socket in the Motor to turn it Really???
/ Hydro help
I just ordered a 24" 1/2" hose and that thread past. I will wait till later to see if there is any more input on what to check before I put the pump back in
/ Hydro help #70
Wow! Got Ya! So that is the Female Hex. in the motor in the pic. above. Then you should be good. As in turning the pump. Back to making sure Fluid is getting to the pump. and nothings coming out Bad Pump!! IMO...
/ Hydro help
Should I try to crank the motor to see if that female hex on engine turns?
/ Hydro help #72
That would be wise. No turn! No turn the Pump! Try turning it first. Easily!!!
/ Hydro help
It spins! Thank god. My guess not building pressure to move the fluid?
/ Hydro help #74
Is it spinning by the motor running. Bad pump. just make Darn sure the Hyd Intake line to the pump is FULL of fluid.
/ Hydro help
I just cranked the motor a little the engine part is fine. the pump spins by hand. Which part is the intake line? I guess my plan is now. Put that loop in check the fluid. That's it for now lol. Not a big plan. Just leave that hose off the pump and keep filling with fluid until it comes out?
/ Hydro help #76
When you removed the plow, there was no place for the oil to flow.
You won't know if the pump is good or bad until you put it all back together with the loop hose on.
Have you ordered an operators manual for the tractor?
/ Hydro help
Anything special I should do after I put the loop on? Or just start her up and try
/ Hydro help #78
Make sure the reservoir is full, then try it.
/ Hydro help
Ok thanks everyone so far for everything and helping me learn all of this.
/ Hydro help
I will post update Friday when I get the parts! Fingers crossed
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
