hydro filter magnet ?
/ hydro filter magnet ? #1
skind
indiana
kubota
I am in the middle of changing my hydro fluid and filter on my l2900 w gst. My ? is the new filter has a magnet where it screws on. It is removable. The old filter did not have a magnet. It does not look like it would block the flow too much. Is it ok to leave the magnet or should I remove it? Thanks
/ hydro filter magnet ? #2
Leave the magnet, it will catch some small metal particles.
/ hydro filter magnet ? #4
Just make sure that the magnet from your old filter isn't already stuck to the filter housing when you screw the new one on.
/ hydro filter magnet ? #5
Thats right. The magnets pull out fairly easily. It could be stuck on the tractor like RedSox1 said. I got a new filter with a broken magnet once. I just swapped the broken one for the old one and was suprised how easy they came off.
Thanks guys. I looked and there was not any magnet on tractor or filter. If there was a magnet stuck on the tractor I can not see the new filter being able to screw all the way on. Just another ? Is there any way to see if this was the original filter it was gray just like the frame of the tractor and did not say kubota on it just some #s on it. Just out of curiosity. Thanks
/ hydro filter magnet ? #7
Its possible its the original filter. How old is your tractor?
/ hydro filter magnet ? #9
My L3130 did not have the magnet on the hydro filter that came with the tractor. Replacement filter did. Upgrade or response to a problem?
David
Dixie Chopper (A64557)
2025 KUBOTA KX033-4 EXCAVATOR (A65053)
2025 KUBOTA...
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
