Hydraulics
/ Hydraulics #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
I have a tractor with a factory Japanese loader that I installed a power steering kit on. The dealer that sold me the kit told me to hook the loader and the PS through a distribution block. When I did this my 3 point lift and loader became extremely slow. Sometimes the hydraulics will lock up and nothing will move including the steering until I jerk the steering wheel a few times. Next to the valve under the seat that adjusts hydraullic down speed is a plug. Is this a pressure port? Could I hook the front loader back in it's original position and hook the steering to this port?
Eugene
/ Hydraulics #2
Unfortanly I do not know how to fix your hyd. problem. But iI am interested in how the power steering kit works and what kind of tractor you have. Thanks, Bryan.
/ Hydraulics #3
Of course, it could be a lot of other things. But it sounds to me, like you just might have a air lock in it somewhere. All it takes sometimes is a little air bubble to lock things up, and slow them down. That is where I would look first.
/ Hydraulics #4
your distribution block is adjusted improperly, you will have to adjust the bypass pressure setting.
/ Hydraulics
I forgot to mention this; the threaded holes for the hydraulic lines on the block are half the size of the original holes on the tractor.
Eugene
/ Hydraulics
Buck,
How do I adjust the distribution block?
Eugene
/ Hydraulics #7
Good question :) can you give me the brand and model #. I would guess it is a dedicated split like 60%/40% or 80%/20%. In other words it takes a specific % of the flow and allocates it for a particular port. Of course when it does that it slows the main flow down so your loader speed goes down. Some are adjustable and you can lower the % it is sending to the power steering. It is done by increasing or decreasing the orifice hole diameter. Usually with a needle valve. If it is not adjustable we will have to put a flow reducer in and see what happens from there.
/ Hydraulics
It is a factory Yanmar add on kit for a 26hp tractor. No instructions came with it, just a drawing of how the parts attached to the tractor. No numbers on the block. The is one place on the block not used. Looks like a hex cap. Don't know if it's another port or some kind of control. Does the fact that I had to reduce the hose ends come into play?
Eugene
/ Hydraulics #9
Smaller hose ends do reduce flow but the Yanmar pumps are so small it shouldn’t matter much. Is there any way to scan or fax me the assembly drawing? I imagine you will find a flow adjuster under the hex cap.
/ Hydraulics
I threw the illustration away after I installed it a year ago. It's not on a Yanmar, it's on a Hinomoto E264.
Eugene
/ Hydraulics #11
Hopefully it can recover from your injection of the Yanmar virus you gave it. Please get it to a doctor quick before it rejects its new organ. /forums/images/graemlins/grin.gif
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
