hydraulics
/ hydraulics #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
I want to build a hyraulic snowblower out of an old combine, Iplan to convert a pto driven blower to hydraulic and mount it on the front of an old combine,the blower will be 7 to 8 feet what I would like to know is what size pump I need and what size hydraulic motor I need.
Thanks in advance
/ hydraulics #3
Welcome aboard. There is a Forum on TBN that is specifically about hydraulics. Perhaps you will find answers there.:tractor::welcome:
/ hydraulics #5
Perhaps if you knew the PTO HP of the tractor that was using it. From there, we can compute the pump input HP and motor output HP to drive the blower.
/ hydraulics #7
Lea; said:
The tractor is 90hp
Lea
Now, the question is how much HP was actually required to run the blower.
Do you have a model number on the blower?
Here are some snow blowers and they use a 22 in fan, and they use different HP on the hyd motor for different width. Essentially more width more HP required.
Here is some hyd data.
They have prices for the hyd motors and the GPM and motor displacement required for the width of the collector.
Beaver Valley Supply Company - Schulte Snow Blowers
These hyd motors are much less expensive.
http://www.surpluscenter.com/item.asp?item=9-7490&catname=hydraulic
http://www.surpluscenter.com/sort.asp?catname=hydraulic&keyword=HML2
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
Case TV380 (A62177)
Case TV380 (A62177)
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
