hydraulics whining
/ hydraulics whining #1
tris7194
kubota l3540 & farmall c
Is it bad when you start up your tractor the 3pt hydraulics whine? And also when the 3pt is picking up something relatively heavy like a bushhog it whines a little. Is this bad????
/ hydraulics whining #2
If the system is low on fluid it might whine. Check your fluid first. In neutral, there is no reason for the 3pt to whine. If picking up a heavy load, the relief might activate and make a sound.
/ hydraulics whining #3
Mine does that every now and then when I forget to unlock the 3-point, and then try to adjust it.
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
