hydraulics weak
   / hydraulics weak #1
adam davis
sabina ohio
john deere B
i have a john deere B that is a 1950 i need to no if i can use motor oil in the hydraulis? and how much it takes? were is the drain plug at on the tratcor?
   / hydraulics weak #8
jd gets 90$ for the paper maual, and a bit less for the one on cd.
the thin flimsy aftermarket I&T manual is 1/3rd that price.
both of them are good reads and worth t he money.
   / hydraulics weak #9
forgot to mention.. I'm at work now and not near my manuals, and it's been way too long since I worked on a B. :)
   / hydraulics weak #10
10w-30 is good. drain plug is just in front of filter cap about seven quarts don't use hydraulic oil fill through the breather on top on the side should be a petcock to check your level
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2016 Freightliner M2106 Cab Chassis (A52377)
2016 Freightliner...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A53843)
RAKE ATTACHMENT...
