Hydraulics qustion
/ Hydraulics qustion #1
CK732
Massy
How easy or hard is it to install 2 more hyd ports?.
/ Hydraulics qustion #3
Assuming you're wanting to add them to your tractor, you need to look at your hydraulic valve assembly to see if you have a "power beyond" port, as well as a output and backflow port for the additional lines. If not, you'll need to replace (or possibly add) another valve body in order to operate add't'l ports effectively.
You can't just go and add a "T" to an existing line like you can for adding a water line to your house.
Yeah it's on my tractor so I'll look and see if I have room on the body.
/ Hydraulics qustion #5
Summit hydraulics has good info on this. I've had good experience with both their products and presales support.
/ Hydraulics qustion #6
Not hard if you know what you are doing and have the ports on the tractor. One of mine needed a power beyond spool and the other was a CaseIH kit that just bolted on. One was cheap and the other about $650. Guess which one.
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2022 EZ-GO ELITE...
159118 (A60430)
159118 (A60430)
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2008 Ford Expedition SUV (A61574)
2008 Ford...
