Hydraulics qustion
/ Hydraulics qustion #1
CK732
Member
Massy
How easy or hard is it to install 2 more hyd ports?.
/ Hydraulics qustion #3
Assuming you're wanting to add them to your tractor, you need to look at your hydraulic valve assembly to see if you have a "power beyond" port, as well as a output and backflow port for the additional lines. If not, you'll need to replace (or possibly add) another valve body in order to operate add't'l ports effectively.
You can't just go and add a "T" to an existing line like you can for adding a water line to your house.
Yeah it's on my tractor so I'll look and see if I have room on the body.
/ Hydraulics qustion #5
Summit hydraulics has good info on this. I've had good experience with both their products and presales support.
/ Hydraulics qustion #6
Not hard if you know what you are doing and have the ports on the tractor. One of mine needed a power beyond spool and the other was a CaseIH kit that just bolted on. One was cheap and the other about $650. Guess which one.
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2018 Trail King Lowboy (A63689)
2018 Trail King...
Freightliner Columbia (A63689)
Freightliner...
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
Brake Drums (A62613)
John Deere 3033R (A64126)
John Deere 3033R...
