Hydraulics Question
/ Hydraulics Question #1
Anonymous Poster
Epic Contributor
I'm setting up a new implement which will be using a new hydraulic cylinder and new hydraulic lines. Question: Do the cylinder and lines need to be primed with hydraulic fluid or will the tractor's hydraulic system (NH TC40D) bleed off the air which might otherwise be introduced?
/ Hydraulics Question #2
Open center systems are self bleeding, closed center will require bleeding. I am not sure which is installed on that tractor , call FNH dealer or check your manual.
According to the manual, it is an open center system. Sounds like I can "bolt it up" and go. Thank you.
/ Hydraulics Question #4
Hi ya
once ya have things up and running shut it down and check ya oil some things( FEL's are bad for this )take alot of oil to fill rams and lines
catch ya
JD Kid
Brand new 3pt 75" 2 stage snow blower with hydraulic chute rotation and hydraulic spout tilt greased and ready to take on old man winter. Thanks again.
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
1997 Hudson Trailer (A62613)
1997 Hudson...
2018 RAM 2500 (A65643)
