Hydraulics Question
/ Hydraulics Question #1
Clarke
South East Pa.
PT425
This morning I connected the mini hoe to do some digging to re-locate and plant. After I removed the mini hoe and connected the pallet forks. The ambient temperature changed quite a bit and I could not get the aux. hydraulic lines to connect without relieving the pressure by loosing the hoses at the cylinder. Is there a fitting or a technique that I don't know about to solve this problem. This has happened several times before when hydraulic quick connects had to be changed.
sg
/ Hydraulics Question #2
Generally, operating the hydraulic controls with the engine off should relieve the pressure. Did you try that?
Yep!!
Doesn't work because it is the implement that is the problem..
sg
/ Hydraulics Question #4
Hydraulic fluid is not supposed to be compressible, so it sounds like you may have air or moisture trapped in the mini-hoe hydraulics somehow. Is there any chance of that, and if so, is there any way to bleed that implement?
/ Hydraulics Question #5
One other thought. Does it make any difference if you shut down and operate the hydraulic controls before disconnecting the mini-hoe?
Actually this time the problem was the quick attach cylinder that I had to bleed the pressure off. I connected the mini hoe in the morning when it was cool. I worked with the hoe for a couple of hours in the hot sun. I guess the aux. hydraulic cylinder heated up from the sun and I could not connect the hoses without relieving some pressure by loosening the hydraulic lines. I have had the problem in reverse not being able to connect the hoe after a temperature increase.
sg
/ Hydraulics Question #7
Once I left the mini hoe in the sun and it build up pressure and I had to manual relieve it. I have used a technique to relieve the pressure off these lines and it works quickly and easily. If it is a male line just take a light hammer or something and rap it right on the end. If that don’t work rap a little harder. It will work. If it is a female connection use a flat ended punch and something to hit the center button inside the quick connect. If that don’t work rap a little harder. It will work. Stay in the middle and straight with just a little care you won’t hurt anything.
/ Hydraulics Question #8
Craig, we've talked about this in the past, but I did the same thing as you, except I put a rag around the fitting first just in case it should try to squirt any oil out. Of course you don't squirt enough out to amount to anything, but I never wanted to take a chance on any hitting me in the eye. /forums/images/graemlins/wink.gif
/ Hydraulics Question #9
Good idea about the rag. I ware glasses all the time so i didn't think about that.
/ Hydraulics Question #10
I had the same problem with my snow plow. Could not get it connected for the life of me. The first time it happened, I cracked a fitting to relieve thepressure. After discussing it here and getting the same tips you have just been given, I now use a large bolt to put against the pin in the fitting, use a rag to hold the bolt and whack the bolt with a hammer. Only a drop of oil comes out, but that is all it takes to relive the pressure.
Does anyone know, while you cannot compress a fluid, does it still expand and contract with temperature? That is the only thing that I can think of that would have caused this. I parked it in the sun for few hours and that is when it happened. I now make it a point to wiggle the aux PTO lever both directions a few times before shutting down and disconnecting. It has never happened since.
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2015 Ford F-150...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2023 New Holland C327 Two Speed Compact Track Loader Skid Steer (A59228)
2023 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
