Hydraulics question
/ Hydraulics question #1
ron45
N.M.
Kioti LK3054XS
What should I be thinking about when one side of a movement loop works faster than it's opposing side.?
So far I have not seen a subject in the topic pulldown menu that relates to anything I want to ask. A tractor minus hydraulics isn't much better that a team of mules. Yet there is no mention of it in this topic list. I don't care if it's never there is it utterly redundant, you could almost venture into spurious. The only thing worse on a web site is tags. Glad they are not here. I think those are just about generating hits for the website using them.
Ron
/ Hydraulics question #2
Ron
On what?
What is a movement loop?
Need more info and pictures.
For a minute I thought my signature stuff was missing or something. Would you believe on a : kioti LK3054XS, backhoe and FEL. Land Pride 6` rear blade with hydraulic cylinder for angle changes. The behavior I'm describing could be on anything that uses a two hydraulic cylinders to extend something and bring it back. If you think about it a minute your other question will come to you. Are you with the nomenclature police? I'll think about my question for a minute and I'll probably have my answer. Thanks anyway.
Ron
/ Hydraulics question #4
If you are talking about what I think you are, the timing bar is bent or gone. Bty what kind of music are you into?
/ Hydraulics question #6
The piston shaft detracts volume from a given cylinder compared to the opposing side and therefore less fluid volume is needed for the same axial movement.
/ Hydraulics question #7
Posts are very hard to read and understand just what the h*ll you are trying to ask.
When using two cylinders, like the loader lift or curl, the fact that everything is rigidly mounted keeps the cylinders in time.
If you want two cylinders to move the exact same amount (provided they are the exact same size cylinders), then you need to make sure they both have the exact same amount of fluid going to them. Not likely with a simple TEE setup. The odds that the resistance of teh cylinders is going to be identical is slim to none. And fluid will follow the path of least resistance. So lacking a rigid setup or "timing" bar, they make what is called a rotary flow divider. One in port, and two out ports. Provides the exact same flow out BOTH exit ports regardless of load on the cylinder. One cylinder could have a load and need 2000PSI to move, and the other have nothing and only require 10 PSI to move....with a tee, the cylinder with no load will fully extend before the one that is loaded will even start. But a rotary flow divider will make them both move the same.
Not sure why you want to know this. I cannot think of anything on a CUT or CUT implement that would require this
/ Hydraulics question #8
For a minute I thought my signature stuff was missing or something. Would you believe on a : kioti LK3054XS, backhoe and FEL. Land Pride 6` rear blade with hydraulic cylinder for angle changes. The behavior I'm describing could be on anything that uses a two hydraulic cylinders to extend something and bring it back. If you think about it a minute your other question will come to you. Are you with the nomenclature police? I'll think about my question for a minute and I'll probably have my answer. Thanks anyway. Ron
Good luck with getting much help from people, no need to respond like this when all he was doing is trying to help.
/ Hydraulics question #9
If one needs to have two cylinders work in unison that is in not in a rigid frame that has little or no twist,
then one needs some type of flow divider to feed both cylinders, regardless of the load on each cylinder,
the other possibility is the use of (I think there called re-phased or timed cylinders), and they have there flow that feed from one cylinder to the next, many large implements use them to control the lift so it is even, across the machine. (but they are special matched cylinders, not just off the shelf unit.
Chief TCR - Re-phasing Tie-rod Cylinders - YouTube
/ Hydraulics question #10
or the other possibility is a torsion bar system that make both work together, in some way,
/ Hydraulics question #11
Came across this guys post had to read a few times and still don't understand. decided to look at his other post and its funny that every post he starts he abandons after the initial post. This is the only post he even has responded to even once since inception.
/ Hydraulics question #12
Seems silly to spend time responding then. Although even the poorest phrased post results in some valuable feedback as evidenced above. Amazing people respond intelligently even after an insulting response from initial unappreciative poster. Indicative of the type if guys and gals on this forum.
So, you find it unexcepttable to help someone find the info they need to ask a pertinent question with in the context of the message? well you get to do that. So do I.
Ron
/ Hydraulics question #14
Wow, over a year later and still have no idea what any of your posts are talking about. Unsubscribing from this mess.
/ Hydraulics question #15
ron45, your question makes little sense to people who use tractors.
You need to grow thicker skin and describe what is not moving in unison that needs to be doing so. Nobody is putting you down or, at least they didn't until you started with acidic replies. If some doesn't understand the question, the issue is probably yours or you chose the wrong audience to speak with. Since this is a tractor forum, you HAVE the right audience.
Now, explain your question with more words and some pics so the people out here can respond intelligently to a question that uses terminology we are not familiar with ... and all may be well, if anyone ever comes back in here after your less-than-friendly replies.
Good luck!
2022 EZ-GO ELITE...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
PRESURE WASHER TRAILER (A65643)
PRESURE WASHER...
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
