Hydraulics messed up ONLY when loader is on tractor
   / Hydraulics messed up ONLY when loader is on tractor
Okay just a quick update. I had to hire a professional to find out that there is a second reservoir of hydraulic fluid. It is located behind/under the seat. It is for the loader and steering. The front reservoir is for the transmission. I had the owners manual and shop guide. The owners manual was very poorly translated and makes no mention of this. I hope this helps someone in the future.
   / Hydraulics messed up ONLY when loader is on tractor #22
That is all well and good, but what was the problem with the lift arms.
Was the problem low fluid?
Did you ever use a hyd gage to test the pressure?
Did you ever check hose flow out of the loader valve?
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
ALLISON TRANSMISSION (A55745)
ALLISON...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
