Backhoe Hydraulics for Backhoe
/ Hydraulics for Backhoe
For my next question. The loader valve has 1" OD steel tubing for the IN and the OUT then it has 1/2" steel tubing with hose to all the cylinders.
Can I run 3/4" from the OUT on the loader valve to the divider valve to the backhoe and back to the reservoir?
/ Hydraulics for Backhoe #62
Yes, although you will have some restriction, probably on the order of going fron 3/8" hose to 1/4" hose which is very common on CUTs. I wouldn't worry about the work ports. Most work port hoses are smaller than the main hoses anyway. My dozer has 1.25" steel for the main circuit and 1/2" hoses for all the work ports.
/ Hydraulics for Backhoe #63
Are you doing this?
Pump >> Loader valve in >> Loader valve out >> Divider valve >> Backhoe >> Tank?
I think you want to do this:
Pump >> Divider (diverter?) >> Loader valve in OR Backhoe in
Monte
I want to do this to keep the original 26 GPM flow to the loader then divide the flow to the backhoe to compensate for the smaller 14 GPM valves in the backhoe.
/ Hydraulics for Backhoe #65
So you'll use one of these and go:
pump >> loader in >> loader out >> divider >> backhoe (priority) AND tank
Surplus Center Item Detail
I hadn't seen those before. Seems like it should work, as long as the divider valve doesn't let the pressure go to the tank port when you load up the backhoe circuit.
Monte
When will I use steel fittings that are JIC and when will I use the NPT. The divider valve specs says NPT.
/ Hydraulics for Backhoe #67
Doesn't realler matter. Use whatever is convenient. Most tractors have a combination of both.
I called Surplus Center today and talked with a tech person. I explained the system that I am proposing (Pump>>Loader Valve>>Divider Valve>>Backhoe Valve>>Reservoir) and the person told me that I will be risking cracking the outlet side of the loader valve or having the loader cylinders working without anyone touching it. He said that there will be a pressure on that side of the loader valve now because of the backhoe valve upstream unlike now with it being a return line.
What do you all think?
I cannot find anyone who makes a 2 spool valve with Power Beyond to replace mine and also fit into the space provided on the loader. Plus the ones that I think there is a possiblity to custom fit them, they are only 25 GPM not 26 GPM.
/ Hydraulics for Backhoe #70
Do you think you'd notice 1 gpm?
Monte
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
STORAGE FEES (A59908)
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
