Hydraulics all froze! What to do?
   / Hydraulics all froze! What to do? #21
I read it as the hydraulics don't move. So I wasn't thinking transmission initially. But then the OP said his PTO would not spin. I can see the power shuttle having an issue (isn't that fluid activated??) but I would think the PTO would be a direct drive. Maybe its more complicated than that?
As others have said, the oil in the transmission will suspend moisture, which can freeze and plug the filter. It doesn't have to look like mayonnaise to be saturated with water. Change the oil and filter and run it.
BTW - over the winter my trans fluid will go from nice and clear to a milky-ish color, because I can never really warm it up enough to vaporize and remove the water. Summertime it clears right up. I'll try running the PTO during warm-up to see if that helps. Thanks for the tip.
   / Hydraulics all froze! What to do? #22
Water will still cause damage to the hydraulics. A high enough percent could crack the case when it freezes. If there was ever a stupid reason to avoid HST this would be one.
I had an old ford 851 that would get water in the transmission. One winter it froze so much it wouldnt move...so yes if you neglect something for long enough anything can happen.
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
