Hydraulics all froze! What to do?
   / Hydraulics all froze! What to do? #21
I read it as the hydraulics don't move. So I wasn't thinking transmission initially. But then the OP said his PTO would not spin. I can see the power shuttle having an issue (isn't that fluid activated??) but I would think the PTO would be a direct drive. Maybe its more complicated than that?
As others have said, the oil in the transmission will suspend moisture, which can freeze and plug the filter. It doesn't have to look like mayonnaise to be saturated with water. Change the oil and filter and run it.
BTW - over the winter my trans fluid will go from nice and clear to a milky-ish color, because I can never really warm it up enough to vaporize and remove the water. Summertime it clears right up. I'll try running the PTO during warm-up to see if that helps. Thanks for the tip.
   / Hydraulics all froze! What to do? #22
Water will still cause damage to the hydraulics. A high enough percent could crack the case when it freezes. If there was ever a stupid reason to avoid HST this would be one.
I had an old ford 851 that would get water in the transmission. One winter it froze so much it wouldnt move...so yes if you neglect something for long enough anything can happen.
2013 Kubota RTV-X900 4x4 Diesel Utility Cart (A55787)
2013 Kubota...
Giyi 44" Rock Bucket (A53316)
Giyi 44" Rock...
2021 KENWORTH T880 5 AXLE DUMP TRUCK (A56129)
2021 KENWORTH T880...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
