Hydraulic Valve Sizing Question
/ Hydraulic Valve Sizing Question #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
My L3010 has a 7 GPM hydraulic capability. If I was going to choose between a 8 GPM max or 20 GPM max single spool dual acting valve to control my grapple would one be better choice than the other? Independent of size and cost. Thanks.
/ Hydraulic Valve Sizing Question #2
It does not matter as long as the valve is rated equal to or greater than the pump output.
I would choose the 8gpm unit because it is probably physically smaller and easier to mount than the 20gpm valve.
/ Hydraulic Valve Sizing Question #3
The 20 GPM valve might also not respond so well on "feathering".....feathering works better if the valve flow rating corresponds to the pump flow....using a way over sized valve, will be like trying to fill a little shot glass with water using a fire hydrant valve....
Thanks for the info. Sounds like all good reasons to go for the 8 GPM unit.
gg
