Hydraulic valve for 3 rd function
/ Hydraulic valve for 3 rd function #1
Bigfrank
Sherwood Park Alberta
B3200HST
Can anyone tell me which is the power beyond plug. I bought this valve for a 3 rd function and im not sure which outlet is for the power beyond. Thanks image.jpgimage.jpg
/ Hydraulic valve for 3 rd function #2
It is probably the large plug in the middle.
Do you have the PB plug?
In the second picture, the yellow center plug is the IN port as it is close to the relief valve to the right.
On the side with the PB plug, the yellow plug is probably the OUT/return port.
No I didn't get one with it. The terrible instructions say that the big steel plug on the side is a conversions plug.what's a conversion plug?
/ Hydraulic valve for 3 rd function #5
The conversion plug is there to plug the hole.
You need a PB adapter to make the valve PB capable.
Here is a picture of two possibilities .
Most valves use the PB sleeve.
Where did you purchase the valve?
/ Hydraulic valve for 3 rd function #7
No, that is just a plug,
What you need will look like one of the pictures.
The first one you show is that not the same as the plug I pulled out just different looking? Sorry for the questions. I was just thinking all I had to do is pull that big plug out and connect. Glad your helping me out. Thanks
/ Hydraulic valve for 3 rd function #11
If that is the one that fits your valve, that is the adapter for the PB.
What that part does is to separate the flow, so that the cyl fluid goes to the tank, and the main flow passes on to the next valve.
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
