Hydraulic Transmision change
/ Hydraulic Transmision change #1
casey lb1914
Upstate, New York
Kioti LB1914
Doing my first hydraulic/transmision, filter change soon on a LB1914. The manual gives several brands to pick from but I'm having trouble finding the brands in the manual. Is there any reason the Travellers brand fron TSC would not work? It's called Premium Universal Hydraulic Fluid, it states that it is a single fluid for transmisions, differential, and wet brakes as well as the hydraulic system. Is this a quality fluid or is there a better option? And If there are any (tricks or watch out for's) before I start the project that might avoid a problem. Thanks
/ Hydraulic Transmision change #2
The fuild from TSC , I have used it on my ck30 with no problem. Just make sure you have a large enough container to catch the old fuild
/ Hydraulic Transmision change #3
Usually what a manufacturer calls for is what meets their "minimum" spec's. There are usually better options just like there is with engine oils and grease. Some better than others, just make sure it at least meets the manufacturers minimum spec.
What does it list in the manual?
THe manual states Multi-Grade Transmission Fluid
Chevron - Tractor hydraulic fluid
Exxon - Torque fluid 56
Mobil - Mobil fluid 350
Pennzoil - Hydra-tranz and wet brake
Quakerstate - Tractor hydraulic
Shell - Donax T-4
Texaco - TDH oil
Union - Hydraulic/ tractor fluid
Valvoline - Unitrac
Where would you find the "Minumum" spec's for this tractor? There's alot to chose from, but finding it on the shelve's is another story. I've called my local Kioti dealer and as usual it's a "not sure". Pennzoil would be my first pick if anyone has seen it out. Thanks again
/ Hydraulic Transmision change #6
It looks like their basically just using a standard UTF oil. So, that being the case you should be fine with the TSC UTF unless you want to upgrade to a premium oil.
4 Bottom Plow (A65640)
New/Unused Landhonor Power Rake (A65583)
New/Unused...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
