Hydraulic fluid
/ Hydraulic fluid #61
I use traveler in my machines hydraulic systems/backhoe/loader which are separate from the trans. For the trans I only use the original manufactures fluid. In my case deere of kubota. My feeling is yes the fluid is expensive but so is a new hydro trans Just my opinion
/ Hydraulic fluid #63
Branson took a different approach, so the filters are not painted over.
/ Hydraulic fluid #64
Here ya go, took me a bit to find it. Post #4 shows the complete video; Yes, they do paint over the Hyd filter (at least with that particular model shown)... Skip to 4:23 and 5:10 of the vid for the primer/painting portions.
Wow.
/ Hydraulic fluid #65
I assume use of hydraulic fluid any brand you are taking in consideration there are different viscosities and formulations along additives. Meaning not all “hydraulic tractor fluid (HTF) can be used in hydrostatic drive. Rather (HTF) is for gear drive tractors. I believe Kubota coins phrase “UDT” for use in hydrostatic whereas the additive package and viscosity is different. Therefore there is difference between “HTF” and Hydrostatic fluids. There are a Lot of cheap oils out there for use that does not make them worthy of 25k plus compact tractor. Unless technical data sheet is citing test specifications with live data you need to be cautious. Marketing will print anything on side of pail if it will assure sale. Not all oils are equal in performance do your homework or plan to pay for repairs in couple years. From hydraulic and hydrostatic pumps to wet brakes bad oil shortens their life. Pretty bucket of oil doesn’t make it good oil but it can assure sale to unaware user since marketing caught their eye and claims it equal to ever tractor specification in the world. Buyer be aware I am speaking from experience on cheap oil.
/ Hydraulic fluid #66
I find that most people use a specific fluid not based on scientific data but on rumor, past habits, superstition and the never ending mantra "you get what you pay for". We assume that if it's expensive it's better. I notice that if you look on the bucket of Travelers Premium Hydraulic Fluid it states that it's compatible with Kioti and every other tractor brand. I also remember an O'reilly Auto Parts employee telling me that their Store Brand synthetic motor oil is made in the same plant that Mobile one synthetic is made.
/ Hydraulic fluid #67
Exactly! Most of the people that bash others because they don't use the brand they use have no clue what it in the brand they use or who actually makes it. They never research for the actual data.
/ Hydraulic fluid #68
You're right about that. The part about being made in the same plant isn't really relevant though. This is common across the board. Made in the same plant does not mean made with the same base oils and made with the same additives.
/ Hydraulic fluid #69
Mobil 1 isn't even synthetic but Mobil was able to take advantage of the total lack of any legal description of what synthetic oil was. I have used Rotella for 40 years and have had 0 engine failures. I use 10w30 in my hydraulic systems with 0 failures. Synthetic fluids have a definite advantage under extreme circumstances but I am convinced that if that is what I thought I had to use 0 failures would have been a good amount more costly. The best oil out there is clean oil.
/ Hydraulic fluid #70
Engine oil is a different beast as full synthetics are common and SAE standards give a lot more assurance of product consistencies brand to brand. The vast majority of THF products (tractor hydraulic fluid) are not full synthetic and there is not a common or a common set of standards that al THFs test to. Mobile 424 is not, Rotella HD is not. AMSOIL is the only one in this category that I know of that's full synthetic. Even UDT2 is only semi-synthetic although many people think it's full synthetic.
/ Hydraulic fluid #71
A year or so ago I ran low on trans/hydraulic oil, so I decided to do some research. Deep in the techo crap papers of TSC oil it said, NOT to be used for heavy duty hydraulic oil.
Now, you tell me when my use shifts from standard duty to heavy duty! IF, somehow it becomes HD does that mean I have to stop doing what I'm doing?
I DID NOT and WILL NOT buy TSC tractor hydraulic oil and I don't care how cheap it is!
On a side note, I know of two cases of guys putting cheap fluid in their John /Deeres that had hydraulic clutch packs and the clutches made noise and were a bit sticky, switching to Deere oil fixed it, and I'm NOT a John Deere person.
SR
/ Hydraulic fluid #72
Just to keep everyone on the same page….
I realize that the title is “Hydraulic Fluid” but the op really needed info about Trans/Hydraulic fluid which is different than Hydraulic fluid.
This is what he was inquiring about…
Traveller 5 gal. Premium Tractor Trans/Hydraulic Fluid​
/ Hydraulic fluid #73
I was surprised to see that Walmart carries 2.5 gallon Mobil Delvac Tractor Hydraulic Fluid, which is the same product as Mobilfluid 424. Mobilfluid 424 is one of the Kioti service manual named fluids to use, even in Hydrostatic tractors.
Walmart link: Robot or human?
I think that you can probably find all the fluid you need if you're willing to drive around to a few Walmarts, the price is pretty decent too, right now it's $43 for 2.5 gallons, and there is a $10 rebate (up to two of them).
Rebate: Mobil Delvac™ – Terms
Case CX75C (A62177)
Case CX75C (A62177)
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
Cherry Picker (A65640)
Mini rock grapples (A61567)
Mini rock grapples...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
