Hydraulic fluid
/ Hydraulic fluid #2
There are plenty of people here on TBN that use that very fluid.
I personally use Kubota sUDT/2 OEM fluid.
Tractor Supply in particular got a black eye years ago for selling a long outdated tractor hydraulic / transmission and marketing it as acceptable in modern equipment. I believe it was a "303" rated fluid, which should never be used in modern tractor transmissions.
/ Hydraulic fluid
I remember the 303 cluster.
Would have liked to use Mobil but it seems non existent around me. I run hydro guard in my 9500 deer combine and deere is very proud of it. The travelers appears to be the only thing around thanks for your input
/ Hydraulic fluid #4
Any one ever use Traveller hydraulic fluid for their Hst kioti ? Can’t find the Mobil orr a couple of the other brands in stock
thanks
Yes. Used it to top off my 2010 DK - 40 since new; AND per my selling dealer, I never changed the hydraulic oil - ONLY filters, HST AND HYDRAULIC, per scheduled maintenance intervals.
OEM filters from Kioti.
Had backhoe, T - N -T, cylinders and diverted valve for front remotes for grapple, snowblower, sickle bar, tree shear.
Just traded it with 1530 hours with NO hydraulic issues; other than small fitting leaks.
YMMV.
CM -
out
/ Hydraulic fluid
I picked up the Kioti filters Interesting about not changing the fluid. Is that recommended in service manual? I'm at 900hrs I thought the hydro fluid should be changed every 400hrs, I'm a little over since my last change at 400
/ Hydraulic fluid #6
If you changed it at 400 hrs, you should be good to go. Remember I NEVER changed it from factory through 1530 hours - and owned it from day one since 2010.
Its common sense that is the fluid stays clear and clean by filtration, (never milky color, indicating water in system); that it's a closed system and doesn't need to be changed out.
I'm living proof of the above. No manual or manufacturer is going to put that in print - duh🤑; they want to sell service and fluids, and their posse of lawyers would have a fit!😎
You do whatever works for you...
I have a brand new CK4020 AND a Kioti 750 track loader, that's $115,000 worth of equipment - I wouldn't risk damaging. Not bragging here, BUT, I owned and ran a foreign auto sales and service business for over ten years; so I had better know what I'm talking about, right?
/ Hydraulic fluid #7
I wouldn't. They have previously sold sub standard tractor fluid and are or have been sued over it.
If you cant find mobil maybe your Co-op has countrymark since your in the midwest.
/ Hydraulic fluid #8
Doesn't your Koiti dealer sell transmission fluid??
/ Hydraulic fluid #9
Not saying to or not to use TSC's home brand - Travelers, BUT, Kioti does sell their own Kioti branded hydraulic oil, which I've used in my Sany SY-50U 5 metric ton excavator, AND will be using it in my new, aforementioned brand new 750 track loader and CK - 4020HST cab tractor.
/ Hydraulic fluid
Yes but its way too expensive
anyone use this below ?
FRAM F760 Universal Tractor Hydraulic Fluid may be used to lubricate all conventional points on an agricultural or industrial tractor as well as in any vehicle that has a common sump. Designed for use in farm equipment, off-highway machinery, industrial tractors, final drives, power take-off units, wet brakes, power steering units & hydraulic systems. RECOMMENDED APPLICATIONS: API GL-4 (Gear Oil); Agco-Allis POWERFLUID 821XL; Allison: C-4, C-3, C-2; Case New Holland (CNH) - MAT 3505 (MS 1209), MAT 3509 (MS 1230), MAT 3525, MAT 3540, MS-1207 (Hy-Tran Plus), MS 3506 (MS 1210) MS-1206 (PTF), MS-1205 (TFD-II), MS-1204 (TFD), M2C48-C, 3510 (MS-1317, GL-4); Caterpillar: TO-2; Clark - TA 12, TA 18, HR 500, HR 600; Dresser CED Trans/Hyd Fluid; Deutz-Allis Chalmers: HTF Power Fluid 821 XL, 272843, 25741, 246634, 25743; Fendt; Fiat-Hesston FNHA-2-C-200.00, FNHA-2-C-201.00, AF-8T; Ford-New Holland: M2C134-A, B, C, D, M2C41-B, M2C43, M2C48-A/B, M2C53-A/B, M2C77, M2C86-B/C, M2C91-A, FNHA-2-C-200.00, FNHA-2-C-201.00; HCE-102, HCE-102W; International Harvester: B-6 (Hy-Tran), B-5; J.I. Case: JIC143 (TFD), JIC144, JIC 145 (TCH), JIC 185 (TFD), MS1204, MS1205, MS1206 (Powergard), MS1207, MS1209, MS1210 (TCH); John Deere: JDM J20C (Hy-Gard), J20 A/B, J21A, J22, J14B/C, JD Type 303; KOMATSU; Kubota UDT; Landini Tractor Hyd Fluid; Massey Ferguson M-1141 (Permatran821 XL, PermatranIII), M-1135, M1143, M1145, M1129-A, M-1127-A/B, M-1110; Minneapolis-Moline; Oliver Type 55; Parker Dennison: HF-0, HF-1, HF-2; Renk Doromat: 873, 874A, 874B; Sperry Vickers: 35VQ25, M-2952-S, I-286-S; Steiger HTF; Valtra G2-08, G2-B10; Vickers I-29986-S, M-2950-S; Vickers Sundstrand - Hydrostatic Trans Fluid; Volvo VCE 1273.03, WB-101, WB-102; White Farm (AGCO) UHTF, Q-1826, Q-1802, Q-1766B, Q-1722, Q-1705, Type 55, Q-186; Yanmar; ZF TE-ML 03E, 05F, 06E, 06F, 06K, 06N, 06R, 17E, 21F; Belarus, David Brown, IMT, Kiota, Leyland, McCormick Farmall, Mitsubishi, New Idea, Renault, Universal, Versatile, Valmet.
/ Hydraulic fluid #11
Sometimes, not always, one gets what they pay for...
Sometimes, probably most often, OEMs buy from giant name brands and under license, they rebrand it under their name.
You're not doing Space Shuttle maintenance here; relax and buy the best most hi-spec brand, and use it with confidence.
CM out
/ Hydraulic fluid
Thanks for everyone's advice Might just do the filters and the oil this time
/ Hydraulic fluid #13
How's that any different from what you did at 400 hrs?
/ Hydraulic fluid
400 hrs did all fluids
I don't change the hudraulic fluid in my combine and most people I know don't do the hydraulics in their deere machines just change the filters
/ Hydraulic fluid #17
I have bought Mobil 424 from Summit Racing on line in the past with free shipping.
/ Hydraulic fluid #19
I use the NAPA brand fluid for my excavator and dont even think twice because it has 5800 hrs. and is good and used. LOL But scared to death to use something other than OEM in the tractor. Sometimes I wonder if it is all the same thing or the OEM's actaully put special "things" in there that their equipment has to have to function properly. It is like a scary movie if you dare use something other than OEM suggestion. :ROFLMAO::LOL:
  • Good Post
Reactions: D&D
/ Hydraulic fluid #20
No OEM makes there own oil that I am aware of, but many have specs good reasons.
Many aftermarket providers (including Napa and Carquest) was selling universal tractor fluid that "meets" JD 303 specs when not only did not meet those specs but something the level of 303 has not been specified for 50 plus years.
Good luck
2013 Ford Escape SUV (A61574)
2013 Ford Escape...
(2) BUCKETS OF GALVANIZED BOLTS (A64281)
(2) BUCKETS OF...
UNUSED WOLVERINE 7' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Informational Lot - Shipping (A63689)
Informational Lot...
1972 CHEVROLET C/60 - 18' GRAIN DUMP TRUCK (A64276)
1972 CHEVROLET...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
