Hydraulic Top Link?
   / Hydraulic Top Link? #31
It's hard to realize how very handy a hydraulic top link is - until you actually get one and use it. It's even harder to put into words. I got my Fit Rite in 2013.
   / Hydraulic Top Link? #32
I only see the need on a box grader. Other than that, it's see no need.
   / Hydraulic Top Link? #33
Well......lets see. I have six land engagement implements plus a chipper. It sure makes connecting the top link a whole lot easier. And I use it to fine tune each of the implements - while in use.
Rather than the implement working - just OK - - it can be tuned to perfection. Makes each of the implements work a whole lot better and easier.
If you like adjusting a manual top link - so be it.
   / Hydraulic Top Link? #34
In addition to all the above, a hyd. top link is also useful for controlling FEL attachments mounted with an adapter on the 3pt hitch. I find it's quite handy for adjusting the angle on a set of forks. It makes it a snap to lift a pallet, especially on uneven ground.
When moving material, I can put a FEL bucket on the 3pt and back into the pile. In addition to doubling the amount of material I can carry in a single trip, it also makes good rear ballast.
I also double the lift I can get with a 3pt boom.
   / Hydraulic Top Link? #35
As you previously mentioned, it's hard to put into words.
If I had never used one I'd want to remain blissfully unknowing.
Having used one for 12 years, I'll never be without.
   / Hydraulic Top Link? #36
How much have you used one, not much? I haven't either but it didn't take me long to realize how useful it would be on things other than the box blade on, especially when I put the boom pole on that tractor with the hydraulic top link.
   / Hydraulic Top Link? #37
I have operated lots of 3point equipment with and without a hydraulic top link, I very highly prefer having the hydraulic top link. But It definitely costs more money.
   / Hydraulic Top Link? #38
I also added tilt to my Kubota. At the time of installing it I added a Quick Hitch. I've never took them off in the last 11 years.
I think the cost justification has to be a personal thing. Some members here rarely use their 3pt or maybe only use it in limited situations.
If a member uses their 3pt on a wide range of implements, as has been mentioned here multiple times, TnT becomes a blessing.
   / Hydraulic Top Link? #39
How much have you used one, not much? I haven't either but it didn't take me long to realize how useful it would be on things other than the box blade on, especially when I put the boom pole on that tractor with the top link.
I have used one plenty. Like I said, box grader needs one. I moved 130 cubic yards in one day. Pulled it up with the box grader, had two dump trucks hauling it, loaded by two skid steers. I know it was 130 because I had figured the needed volume plus 20% addition for compaction of loose fill. Everything worked out, so my 130 number was fine.
   / Hydraulic Top Link? #40
Well, evidently, based on your assessment of the need for a top link, your use has been very limited. :)
2016 HYUNDAI Veloster Hatchback (A56859)
2016 HYUNDAI...
2013 Yamaha Club Car (A56859)
2013 Yamaha Club...
1643 (A58375)
1643 (A58375)
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
