Hydraulic top link
/ Hydraulic top link #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
Does anyone know whats involved in retrofitting my B2710 with a hydraulic top link? I saw my brother-in-law's old 50 HP Kubota M tractor which has a hydraulic top link plus hydraulic height adjustment. Gotta have it for the box blade!!!! Unless there's too much $$ involved.
Alan L., TX
/ Hydraulic top link #2
Alan,
I want one too! Do a search for top and tilt and you should find lots of information. Bird did his own on a 2710 and was good enough to share all the details. The down side is the $800-1000 price tag.
MarkV
/ Hydraulic top link #4
I've got a few other questions for those of you who have already done TnT conversions. This applies to the 2710/2910 models, and perhaps others as well.
On the top link cylinder, I think you need swivel balls on both ends of the cylinder, just line on both ends of the manual top link. Did you get cylinders pre-fab'd this way or did you add the swivels, and if so how.
One the side cylinder, the fixed lift link has an angled end at the top where it hooks to the lift arm. How did you deal with this? Just ignor it and use a cylinder with straight brackets? Custom make something?
Thanks,
Peter
/ Hydraulic top link #5
Alan, I used Tisco products and cylinders that were supposedly meant to be used on B8200/B9200 tractors. I had to shorten the top link cylinder, and add some brackets to the side link cylinder to get mine to work the way I wanted it to. From what I've read on the forum, I think GlueGuy is right; you should check with Gearmore. I think they not have a kit for the B2710 that would be better.
Bird
/ Hydraulic top link #6
Glueguy,
I have a silly question for you. How does the TnT affect the lifting of the 3ph arms? I mean the purpose of the hyd toplink is to push or pull the blade forward and back and the side cylinder allows the blade to angle sideways for ditches, crowning etc. I guess I'm not understanding how having the two cylinders attached doesn't affect the normal up and down motion of the 3ph arms? What am I missing?
/ Hydraulic top link #7
<font color=blue>How does the TnT affect the lifting of the 3ph arms?</font color=blue>
Grant, it doesn't affect what the 3-point lift arms do, except that, depending on the way it's plumbed, you may not be able to adjust the top link and the 3-point height simultaneously.
Bird
/ Hydraulic top link #8
Alan,
I would also check with Gannon/Woods to see if they have a kit for your machine. They offer their "Power Link" kit for many tractors. I am not sure if they have a kit for the 29xx (I have their kit for a L4310.) I would recomend you buy a kit vs trying to piece everything together. My dealer charged $50 for installation of the cylinders, hoses, and 3 spool valves. Best $50 I have ever spent. I think the kit was ~$1000 for 2ea 4" cylinders and 3 valves (top Tilt, and one extra for the box scraper rippers).
Hope this helps,
-Roger
/ Hydraulic top link #9
Alan, I have a 2910 with a Gearmore supplied T&T kit. Best $700 I've ever spent on farm stuff. Don't leave the barn without one!
Larry...
/ Hydraulic top link #10
On my Gearmore TnT, the top link cylinder has swivels on both ends. The side link cylinder has the brackets angled exactly like the manual link has. The dealer had the original manual links packaged up for me when he delivered the tractor. I took the original fixed side link opposite from the hydralic one off, and replaced it with the manual one that was originally mounted on the other side. Don't know if I'll ever use it, but it allows a little more tip than I would otherwise have (even if it's manual on the one side)./w3tcompact/icons/smile.gif
The GlueGuy
/ Hydraulic top link #11
Grant,
Exactly like Bird says. The hydraulic link doesn't stop anything from working the way it did before. It just takes the "manual" out of changing the length of the top link.
The GlueGuy
/ Hydraulic top link #13
<font color=blue>Does Gearmore have a web site?</font color=blue>
As a matter of fact they do: http://www.gearmore.com (not too hard to find /w3tcompact/icons/wink.gif).
They have lots of good downloadable equipment brochures and specs, but I don't recall seeing the Tip 'N' Tilt. Could be I just didn't see it. /w3tcompact/icons/crazy.gif
/ Hydraulic top link #14
I just finished my TnT. I figured my cost at about $550 for all the parts that are installed on the tractor.
I bought my cylinders from Northern. I bought the top link end swivels from my local tractor shop for ~$10. One was welded on the rod that comes out of the cylinder. For the other end, I had to do some minor rework on the cylinder end, and then welded the swivel to the end.
For the side link, I fabricated a new angled end for it, and welded it to the end of the rod. For the top connection, I left the cylinder alone. Using a clevis pin, I fabbed bushings that fit the tractor and cylinder. All the angles match up with the original components. My original side link is completely intact, just in case I ever need it as a backup or?
The one thing I would look at if I did this again, is using welded cylinders instead of tie-rod cylinders. The tie-rod cylinders I used are somewhat large in overall diameter compared to a comparable welded cylinder. Welded cylinders though, are more $$$.
I did have to lengthen the fixed side link just a bit; the overall centered length of the side cylinder was a tad longer.
I am fortunate that a friend has a metal fab shop. He has torches, arc welders, cutoff tools, metal stock ect. If not for that, it would have cost more to have a shop do the fab work.
One thing I would think about too, is quick connects for the top link. I went to use my post hole auger, and it dawned on me it does not use the top link; I had to bungee cord the top link to the ROPS temporarily.
RobertN in Shingle Springs Calif
/ Hydraulic top link #15
A couple months ago, I saw a Boomer with hydraulic cylinders on both sides of the 3pt. I imagine he got some impressive angles out of his box scraper!
/ Hydraulic top link #16
<font color=blue>hydraulic cylinders on both sides of the 3pt</font color=blue>
Yeah, my friend/neighbor with the B7100 has cylinders on both sides of his 3PH, and he can really tip that baby. He does a most excellent job cleaning out the ditches on the side of the road. In fact, he can do an impressive job digging shallow trenches with his setup.
The GlueGuy
/ Hydraulic top link #18
If you can't find the Gearmore T&T on their web site, I have their complete catalog and I know it's in there. I can probably scan the page and post it. Let me know.
Larry...
/ Hydraulic top link #20
Thanks Harv,
I found Gearmore on my own after I had ask the question. I don't know why it didn't come up the first time I tried. I also could not find any Top N Tilt info on there site, but I did E-mail them. I'll let you know what they have to say when they reply.
MarkV
(18) 10'-6" PVC CONDUIT PIPE (A60432)
(18) 10'-6" PVC...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
207273 (A52708)
207273 (A52708)
UNUSED FUTURE P45-56" HYD MINI BREAKER HAMMER (A60432)
UNUSED FUTURE...
