Hydraulic top link question
/ Hydraulic top link question #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
So with some Xmas money I decided to get a hydraulic top link. Seems to work great rather then having to manually adjust the top link to fit 5 implements.
So yesterday I used my fire wood splitter. This was the first time I required to disconnect the top link from single remote on the back of tractor.
So I backed into position splitter is on a 24" high roll able cradle . Hook up get things where they attach . lift the splitter and play around with the top link.
and off I go.
Get to the pile of wood Disconnect the top link hook up the splitter . Split my wood . Finish head back to the garage to drop off the splitter.
When I get there I can't get the top link to attach to the fittings as its under pressure from the weight of the splitter.
I took the hose and pressed the end button to remove the pressure it blasted fluid out all over the ceiling and my face . Second time in 50 years I was glad to where glasses. The splitter dropped an inch or two and still had lots of pressure.
So what I did was lifter the splitter with the 3pth rested it on the cradle and removed the pressure again so the hoses could be hooked up.
So is there a way to attach a pressurized hose to a coupler ? Or what is a better way to do what I have to do.
Yes I realize a second remote is the way to go .
My other implement is a wood chipper that will require a top link hose removal. Because that rests on the ground there shouldn't be a problem to relive pressure in the hose.
I guess if I get longer hoses then the splitter could be lowered to the ground also.
/ Hydraulic top link question #2
They do make some connect under pressure versions of different fittings, but they are expensive, and I dont think they come in "AG" style.
Easiest would be to get longer hoses for the logsplitter, so you can sit it on the ground when done and then reconnect the toplink.
/ Hydraulic top link question #3
No more then you will be having to disconnect/reconnect just turn the tractor off, cycle the remote valve to relieve pressure then disconnect/reconnect your hose for whatever your hooking up. That is what I always did on our skidsteer when hooking the grapple bucket or backhoe so there wouldn't be pressure, I have been sprayed before too and it isn't fun.
/ Hydraulic top link question #4
A "poor man's" approach to expensive QDs would be to add some ball valves on the cylinder side of the top link. Close the valves when the link is under no pressure and DC. The second option would be to rig up a chain or something that you could attach to the tractor and the Implement so the top link doesn't have weight on it.
/ Hydraulic top link question #5
Seems like the simplest solution would be to use the regular top link. You could also get a diverter setup like used to add 3rd function to loaders to add a second set of remotes.
I saw an add on craigslist recently that was a 3pt log splitter mounted to a trailer. You could get one of those cheap trailer kits from Harbor Freight and do that. Same operation, easier hookup and dropoff.
Why do you need to hookup the toplink to drop off the splitter?
/ Hydraulic top link question #6
{Edit Darn I'm a slow typist ^^^ yea, what he said}
Use the old screw type top link for the splitter... it's not like you need to adjust it a whole lot. There's somethings that are not better with the hydraulic top link. When I mow with my finishing mower, I remove the top link.
I like the idea of a chain to support the weight .
/ Hydraulic top link question #9
You've just been splitting wood. So just grab a piece and set it up so that you can rest the rear of the splitter on it. Remove your hoses and continue on your way.
/ Hydraulic top link question #10
I am gonna have to agree with using your original toplink on this. If you don't have one, get a cheap one for use with the splitter. Problem solved.
That works too as well a manual top link
Thinking now if I had a manual top link for all my implements it would be cheaper then a hydraulic top link.
Too late though.
/ Hydraulic top link question #12
/ Hydraulic top link question #13
I have a home made hydraulic top link and use it with a quick hitch. I can weld so I modified all of my implements except one to work with the quick hitch. I wouldn't want to be without it.
/ Hydraulic top link question #14
Get extra remotes so you never have to unplug the toplink. ;-p
/ Hydraulic top link question #15
My thoughts exactly.
Doing this is much faster and easier than removing your hydraulic top link and installing a manual one just to use your splitter. Those hydraulic cylinders are kinda heavy.
/ Hydraulic top link question #16
Set the implement down so it removes the weight from the toplink. Turn off the tractor, cycle the control valve back and forth to relieve the pressure. Operate the quick disconnect normally.
/ Hydraulic top link question #17
I'm with John_Mc and others, I set the implement down, shut off the tractor and cycle the hydraulics. Been doing it since my first hydraulic implement.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2021 International HX620 Quint Dump (A62613)
2021 International...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
