"Hydraulic Thread" Can Someone Identify This?
   / "Hydraulic Thread" Can Someone Identify This?
Yes it does and can tee into the QD. Thanks!
Thinking I might be able to chain the upper crank arms down to the drawbar to hold the 3PH down. Shouldn't be too much chain load with a heavy implement on the back.
Or may be able to pull the pins where the lift links attach to the lower links and then move the lift links all the way forward and repin them under the lower links to reduce the leverage.
It's a bit cold here to mess around outdoors attaching to a tree.:)
   / "Hydraulic Thread" Can Someone Identify This? #22
I tried this without success. There was enough leakage past the bolt threads that was showing only 500 PSI on the gauge. Took me a little while to figure out what was going on. The leakage, of course, was going into the return line.
It didn't work and won't work like described because they are straight threads. Gotta tighten down against a sealing washer or o-ring to seal.
Can you put a tee with the gauge in the pressure line somewhere ahead of the 3 point valve?
Does it have a loader with quick disconnects?
Yes, I teed into the loader power beyond with the gauge and QD's and got 2000 psi which is right on spec. Glad to not have to adjust the 3PH relief valve as it's difficult to access. Just thought the pressure needed to be checked after nearly 30 years of use.
Was able to disconnect the vertical lift links and reconnect them up close to the lower lift links front pivot so the 3PH had not enough leverage to lift a heavy duty landscape rake.
Thanks to everyone for input.
   / "Hydraulic Thread" Can Someone Identify This? #24
Man TBN (actually the people on it) is awesome!
2013 Ford E-250 Animal Cargo Control Van (A48081)
2013 Ford E-250...
2013 BMW X3 AWD SUV (A48082)
2013 BMW X3 AWD...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
JCB 3CX 15HFCE BACKHOE (A51242)
JCB 3CX 15HFCE...
