npalen
Elite Member
Yes it does and can tee into the QD. Thanks!
Thinking I might be able to chain the upper crank arms down to the drawbar to hold the 3PH down. Shouldn't be too much chain load with a heavy implement on the back.
Or may be able to pull the pins where the lift links attach to the lower links and then move the lift links all the way forward and repin them under the lower links to reduce the leverage.
It's a bit cold here to mess around outdoors attaching to a tree.
