Hydraulic test port kit
/ Hydraulic test port kit #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
On both of my mini excavators on the pressure side 90 degree fittings there is a allen plug. On my cheap micrometer it shows the outside diameter of the plug threads is .375 The 1/4-28 thread seems to match the pitch of the plug but not the diameter. 1/8 pipe seems too big. I am trying to come up with an adapter to check pressures. The machine in a Kubota KX 121-2 excavator. Anyone have any adaptor leads?
/ Hydraulic test port kit #3
Does this plug have a seal washer or does it look more like a tapered set screw?
If seal washer could be 1/8 BSPP
It is a tapered thread with no washer. I am thinking its 1/8-BSPT The manual says 1/8 PT but when i google around, alot of people have run into this trying to put oil pressure gauges on their tractors. The gauges are NPT and the factory Hole is BSPT. All I can find is brass adapters but I am not sure about 3000+ PSI on Brass.
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2012 FORD F-450 4X2 S/A SERVICE BODY (A66091)
2012 FORD F-450...
2009 INTERNATIONAL 7600 6X4 T/A  VACUUM TRUCK (A66091)
2009 INTERNATIONAL...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
