hydraulic stand pipe and diverter block problems
/ hydraulic stand pipe and diverter block problems #1
Spag1
englad
massey ferguson 135
Hi, im very new here and also very new to tractors so my questions may seem simple/basic/stupid?? we all start somewhere i guess! And apologies to lots of incorrect terminolgy.
I have a late 60's Massey Ferguson 135, it has pressure control. I am fitting a loader to the front so attempted to fit a diverter valve. There are 2 tubes, one is stand pipe the other is behind it, it has a dogleg bend in it and is supposed to fit into the tee block attached to the standpipe. I can get the standpipe into the pump on its own, but cannot locate the other tube (pressure control tube???) into the tee block at the same time. It will start to locate but will not push down past the o rings i guess. Iam thinking of removing the whole lift cover and whilst im in there change the o rings on the standpipe etc...
Is there an idiots guide to removing the lift cover, preferably with photos??
Hope you can help
Thanks in advance
/ hydraulic stand pipe and diverter block problems #2
Hope you can help
Thanks in advance
Do a search for a thread by klancf51. I think it was titled "help with Massey 135 standpoint with pressure control". Also a thread servicing the hydraulic standpoint.
/ hydraulic stand pipe and diverter block problems #3
Thanks for the links, I guess I need to work my round the forum and learn to use the serch function...Cheers
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
