Hydraulic shuddering...
/ Hydraulic shuddering... #1
sendero
Grayson County TX
Kioti DK35
... I have a DK35 - owned it about a year and have put just 25 hours on it (I know, I want to use it more but... /forums/images/graemlins/smile.gif )
The last time I hooked up the bush hog, I noticed that when I lower its position it shudders down rather than going down smoothly.
One person suggested that maybe I needed to add hyd fluid, but according to the dipstick, it is fine.
I assume I should try to fix this - it can't be good. Any ideas?
/ Hydraulic shuddering... #2
Do you have the valve that controls the drop speed opened up?
/ Hydraulic shuddering... #3
I agree with Chris, adjust the 3pt. drop speed control which is probably under the front of the seat just above the platform. All closed, clock-wise when seated and looking down, keeps the 3pt from dropping, to the other end of the 3pt dropping quickly. John
I have that valve almost wide open. Isn't that what I should have?
/ Hydraulic shuddering... #5
</font><font color="blue" class="small">( I have that valve almost wide open. Isn't that what I should have? )</font>
Nope, there's your problem. /forums/images/graemlins/wink.gif The lighter the implement, the more you open it, and the heavier the implement the more you close it, and a brush hog is a lot of weight back there.
And Billy, after not hearing from you for nearly 6 months, I thought you'd been so busy you'd have lots of hours on that tractor. /forums/images/graemlins/wink.gif
/ Hydraulic shuddering... #6
Bird said it well. Just close it down to where it easily, but not too quickly drops, move it a few times, and it should get better. John
Well, now I feel kinda stupid /forums/images/graemlins/smile.gif Of course that is the problem.
Well, I've been pretty busy but the main reason I don't use my tractor more is that there is only so much mowing I'm permitted to do because of wildlife considerations /forums/images/graemlins/smile.gif
But I am getting a pond built (well, actually I'm expanding my 1/2 acre or so pond to 2 acres or so). They are about 2/3s done with it and I'm hoping they finish it up before we get more real rain here /forums/images/graemlins/smile.gif
/ Hydraulic shuddering... #8
That looks like a pretty serious project. A 2 acre pond ought to make a good fishing hole. Hope you have fun with it.
Don't you worry, I will have fun with it /forums/images/graemlins/smile.gif
/ Hydraulic shuddering... #10
Wow that's going to be HOT, or cool with water! /forums/images/graemlins/grin.gif
glad you got your problem straightened out. Easy to forget those little things exist when you don't get a chance to use them! John
2020 DRAGON ESP...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 NORAM 65E TURBO MOTORGRADER (A60429)
2021 NORAM 65E...
Eagle Weathervane (A55853)
Eagle Weathervane...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
