Hydraulic shuddering...
/ Hydraulic shuddering... #1
sendero
Grayson County TX
Kioti DK35
... I have a DK35 - owned it about a year and have put just 25 hours on it (I know, I want to use it more but... /forums/images/graemlins/smile.gif )
The last time I hooked up the bush hog, I noticed that when I lower its position it shudders down rather than going down smoothly.
One person suggested that maybe I needed to add hyd fluid, but according to the dipstick, it is fine.
I assume I should try to fix this - it can't be good. Any ideas?
/ Hydraulic shuddering... #2
Do you have the valve that controls the drop speed opened up?
/ Hydraulic shuddering... #3
I agree with Chris, adjust the 3pt. drop speed control which is probably under the front of the seat just above the platform. All closed, clock-wise when seated and looking down, keeps the 3pt from dropping, to the other end of the 3pt dropping quickly. John
I have that valve almost wide open. Isn't that what I should have?
/ Hydraulic shuddering... #5
</font><font color="blue" class="small">( I have that valve almost wide open. Isn't that what I should have? )</font>
Nope, there's your problem. /forums/images/graemlins/wink.gif The lighter the implement, the more you open it, and the heavier the implement the more you close it, and a brush hog is a lot of weight back there.
And Billy, after not hearing from you for nearly 6 months, I thought you'd been so busy you'd have lots of hours on that tractor. /forums/images/graemlins/wink.gif
/ Hydraulic shuddering... #6
Bird said it well. Just close it down to where it easily, but not too quickly drops, move it a few times, and it should get better. John
Well, now I feel kinda stupid /forums/images/graemlins/smile.gif Of course that is the problem.
Well, I've been pretty busy but the main reason I don't use my tractor more is that there is only so much mowing I'm permitted to do because of wildlife considerations /forums/images/graemlins/smile.gif
But I am getting a pond built (well, actually I'm expanding my 1/2 acre or so pond to 2 acres or so). They are about 2/3s done with it and I'm hoping they finish it up before we get more real rain here /forums/images/graemlins/smile.gif
/ Hydraulic shuddering... #8
That looks like a pretty serious project. A 2 acre pond ought to make a good fishing hole. Hope you have fun with it.
Don't you worry, I will have fun with it /forums/images/graemlins/smile.gif
/ Hydraulic shuddering... #10
Wow that's going to be HOT, or cool with water! /forums/images/graemlins/grin.gif
glad you got your problem straightened out. Easy to forget those little things exist when you don't get a chance to use them! John
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
3268 (A63117)
3268 (A63117)
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
