Hydraulic schematic Adding remote to BX25 TLB
/ Hydraulic schematic Adding remote to BX25 TLB #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Anybody have a hydraulic Schematic for a BX25 TLB?
I want to add a set of rear remotes. I understand there is no factory kit available for the TLB, but a homebrew setup should be relatively simple to make.
I should be able to plug the rear remote valve into the PB loop and hook the Tank port to the tank fitting used when using the rear backhoe. Correct?
I'd like to have the valves removable so when im using the backhoe they wont be in the way.
/ Hydraulic schematic Adding remote to BX25 TLB #2
I would like to do the same thing.
Selecting the valve seems the hard part. I don't know what specs to shop for.
i think that any open center dcv should work
2461 (A58376)
2461 (A58376)
Forklift (A56857)
Forklift (A56857)
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
