hydraulic scarifiers
/ hydraulic scarifiers #2
Only if you have a ton of money and already have everything else, in which case I would just hire the work done.
/ hydraulic scarifiers #3
</font><font color="blue" class="small">( Hydraulic scarifiers on a box scraper. Worth having? Or not? )</font>
If you already have (or are planning on installing) a TnT with 3-spool valve, then it may be worth it. It will probably add about $500 to the cost of a typical subcompact box scraper. Also, if you already have (or are planning to install) a rear remote, and won't be using it for a hydro toplink, then it also may be worth it. What it does is allow you to quickly switch between ripping and scraping w/o ripping, or to adjust how deep you rip while still scraping.. If this isn't important to you, then there's no need to get it.
/ hydraulic scarifiers #4
I have TnT and since I do not use my BB commercially, I am happy with the in between solution. That is: one spring assisted lever that raises and lowers the scarifiers all at the same time. So far for each project I get on and off the tractor about three times for about 15 seconds to adjust the scarifiers. I guess it depends on how much BBing you plan on doing if it would be worth it for you.
Ground Protection Mats (A64047)
Ground Protection...
159120 (A60430)
159120 (A60430)
2019 CAT 259D (A60462)
Wolverine Skid Steer Tree Digger (A64047)
Wolverine Skid...
16ft Southland enclosed trailer (A64047)
16ft Southland...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
