hydraulic scarifiers
/ hydraulic scarifiers #2
Only if you have a ton of money and already have everything else, in which case I would just hire the work done.
/ hydraulic scarifiers #3
</font><font color="blue" class="small">( Hydraulic scarifiers on a box scraper. Worth having? Or not? )</font>
If you already have (or are planning on installing) a TnT with 3-spool valve, then it may be worth it. It will probably add about $500 to the cost of a typical subcompact box scraper. Also, if you already have (or are planning to install) a rear remote, and won't be using it for a hydro toplink, then it also may be worth it. What it does is allow you to quickly switch between ripping and scraping w/o ripping, or to adjust how deep you rip while still scraping.. If this isn't important to you, then there's no need to get it.
/ hydraulic scarifiers #4
I have TnT and since I do not use my BB commercially, I am happy with the in between solution. That is: one spring assisted lever that raises and lowers the scarifiers all at the same time. So far for each project I get on and off the tractor about three times for about 15 seconds to adjust the scarifiers. I guess it depends on how much BBing you plan on doing if it would be worth it for you.
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 98,157 (A64557)
Year: 2016 Make...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2022 EZ-GO ELITE...
