hydraulic Rototiller
   / hydraulic Rototiller #1
mentat30
Waupaca, WI
Kubota BX2350
Are hydraulic Rototillers any good? How do they compare to pto rototillers? What kind of hydraulics do you need to run them? Thanks!
   / hydraulic Rototiller #2
Cost about 2 or 3 times more than the pto kind from what i've seen.
   / hydraulic Rototiller #3
Your tractor would not have the rated GPM (gallons per minute) to run one.
Really? The one that I am looking at is only a 42", a good friend of mine said rototillers of that size need only about 2-3gpm. When I posted the question, I had not talked to him. So do you think one of that size would need more then 6gpm?
   / hydraulic Rototiller #5
Do you have a manufacturers name and model # of the unit you are looking at? 2-3 GPM sounds very low to me...
Sorry, I all I know is its a Case 42" rototiller and it was last used on a Case 646. Does that help?
   / hydraulic Rototiller #7
I just put a 42 inch jd hydro tiller on my 855 last week and it ran great, it is running off a rear pto pump
   / hydraulic Rototiller #8
I think I found the one you are looking at on Craigslist...I think It might be a good deal, and I appologize for misleading you on the GPM. I was invisioning a larger skid-steer style tiller.
   / hydraulic Rototiller #9
Do they not run off the PTO? I thought I had heard of one a while back that had it's own pump powered by the PTO or something like that.
How much for that size?
kennyd, not a problem. I am new at this stuff so I appreciate the advice. So do you think it would work with my tractor?
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
Guard Rail Joints (A51692)
Guard Rail Joints...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
UNUSED RAYTREE RMH680 HYD HAMMER (A51248)
UNUSED RAYTREE...
