hydraulic Rototiller
   / hydraulic Rototiller #1
mentat30
Waupaca, WI
Kubota BX2350
Are hydraulic Rototillers any good? How do they compare to pto rototillers? What kind of hydraulics do you need to run them? Thanks!
   / hydraulic Rototiller #2
Cost about 2 or 3 times more than the pto kind from what i've seen.
   / hydraulic Rototiller #3
Your tractor would not have the rated GPM (gallons per minute) to run one.
Really? The one that I am looking at is only a 42", a good friend of mine said rototillers of that size need only about 2-3gpm. When I posted the question, I had not talked to him. So do you think one of that size would need more then 6gpm?
   / hydraulic Rototiller #5
Do you have a manufacturers name and model # of the unit you are looking at? 2-3 GPM sounds very low to me...
Sorry, I all I know is its a Case 42" rototiller and it was last used on a Case 646. Does that help?
   / hydraulic Rototiller #7
I just put a 42 inch jd hydro tiller on my 855 last week and it ran great, it is running off a rear pto pump
   / hydraulic Rototiller #8
I think I found the one you are looking at on Craigslist...I think It might be a good deal, and I appologize for misleading you on the GPM. I was invisioning a larger skid-steer style tiller.
   / hydraulic Rototiller #9
Do they not run off the PTO? I thought I had heard of one a while back that had it's own pump powered by the PTO or something like that.
How much for that size?
kennyd, not a problem. I am new at this stuff so I appreciate the advice. So do you think it would work with my tractor?
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
REMLINGER 2300 LOT IDENTIFIER 255 (A53084)
REMLINGER 2300 LOT...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
