hydraulic Rototiller
   / hydraulic Rototiller #1
mentat30
Waupaca, WI
Kubota BX2350
Are hydraulic Rototillers any good? How do they compare to pto rototillers? What kind of hydraulics do you need to run them? Thanks!
   / hydraulic Rototiller #2
Cost about 2 or 3 times more than the pto kind from what i've seen.
   / hydraulic Rototiller #3
Your tractor would not have the rated GPM (gallons per minute) to run one.
Really? The one that I am looking at is only a 42", a good friend of mine said rototillers of that size need only about 2-3gpm. When I posted the question, I had not talked to him. So do you think one of that size would need more then 6gpm?
   / hydraulic Rototiller #5
Do you have a manufacturers name and model # of the unit you are looking at? 2-3 GPM sounds very low to me...
Sorry, I all I know is its a Case 42" rototiller and it was last used on a Case 646. Does that help?
   / hydraulic Rototiller #7
I just put a 42 inch jd hydro tiller on my 855 last week and it ran great, it is running off a rear pto pump
   / hydraulic Rototiller #8
I think I found the one you are looking at on Craigslist...I think It might be a good deal, and I appologize for misleading you on the GPM. I was invisioning a larger skid-steer style tiller.
   / hydraulic Rototiller #9
Do they not run off the PTO? I thought I had heard of one a while back that had it's own pump powered by the PTO or something like that.
How much for that size?
kennyd, not a problem. I am new at this stuff so I appreciate the advice. So do you think it would work with my tractor?
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
Kubota RTV500 (A47384)
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
